Yes many people say the K-jet has a theoretical limit and with smaller the airflow meters thats true, but they did use K-jet on turbo porsches and the old school euro racers, I think even F1 used it at one point. The beauty of the system is you can interchange parts from other cars with a little ingenuity, for example if you wanted to you could fit a 6 cylinder airflow meter and plumb in 2 extra injectors at the top of the inlet manifold etc., imagine using one of a V8 mercedes :twisted:.
As for the cold start injector on at full throttle, I think that might be possible on the KE-Jet cars that have lots of other electrical imputs(exhaust gas analyser etc.) to the computer that can adjust the fueling back to a safe level. But on a standard K-jet it would just waste fuel and give a bad mix, as they run a tiny bit too much fuel as standard, I know mine drops a little bit of black smoke(unburnt fuel) at high revs and is standard.
One trick when turboing a K-jet is to use a WUR(warm up regulator from a turbo car) from an Audi etc. as they have a boost input tube that u run off the manifold and it increased te fuel that way(one of many). Also a rising rate fuel pressure regulator would be good but haven't seen them on the market for K-jet(extemely high pressures compared to EFI) for ages.
