Results 1 to 10 of 11
Thread: To Gurny or Not to Gurny
    Sep 2006
    Australia?
    Question To Gurny or Not to Gurny
    Hey guys,
    I was just wondering if it is safe to gurny the mk1 engine bay?
    And if anyone does what kind of detergent stuff do you guys use?
    Aug 2006
    dish washing liquid is d best
    Oct 2005
    Nowra, NSW
    Should be ok, just don't hit the plugs, dizzy, coil etc.
    I would suggest blowing it all dry afterwords with a compressor or I wouldn't do it.
    Dec 2007
    Ermington, Sydney
    Steve I did it to my engine...two of my engines in fact. Just completely cover up the electrical components (as static said^^^) and get some degreaser or carby cleaner....leave it to chew through the dirt then blast away. Then grab a compressor and blow the crap out of the electrical components even if they were covered
    Jun 2006
    Orange NSW
    Kenco "Shift It" in a pump bottle man. That shiz is awesome! Spray on, let it sit.. Hose off.
    Sep 2006
    Australia?
    Thanks guys sounds good!
    Quote Originally Posted by Mrk_Mickey View Post
    I know bro I did it to the mk3 all the time no sweat just didn't know the process for a mk1 with the electricals and that
    Perth. WA
    cleaning
    just take it easy around the radiator, the water pressure can deflect the fins without to much effort ( wash froma greater distance to lower the impact pressure..)
    i dont worry about the electricals, just blow it all down after with compressed air, then CRC spray the elecrical joints..
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Oakleigh VIC
    I get the engine hot then hit it with an entire can of $2 degreaser from supercheap. Let it sit for a while then pressure wash it using a kero gun full of boiling water and truck wash.
    Usually only take a couple of litres of boiling water to clean it all up.
    Pete
    Mar 2007
    South Brisbane
    Normally its done when engine is cold with a hot engine you can potentially crack your block, radiator, exhaust manifold etc..etc... you can do it while its hot but its generally not recommended, what ive been doing for years and its the way ive been shown is degrease the engine bay hose it down with a gurney or a hose then start the car and let it run until hot this will evaporate any water or moisture that has gotten into the electrical system eg dizzy.
    Oakleigh VIC
    Quote Originally Posted by revnit View Post
    Fair point, I didn't mention how long I let it sit for once I hit it with the aerosol degreaser. I usually let it sit for at least 1/2 an hour before hitting with the boling water, sometimes overnight. Even so I am using boiling water not cold water so any thermal shock should be minimal.
    A Gurney is much higher pressure than my kero gun though, I'd be very careful with one of those things, I've seen them tear timber window frames to bits!
    Pete
