3 Days of trying later (Even through a friend in Japan) A good condition 14B turbo was never going to be found at a decent price. So I made the inevitable decision of using a T25 turbo from a stock SR20DET (Nissan) engine. The flow rates were much the same though the T25 had a smaller overall foot print. This will make it easier getting to bolts if it ever has to come off.
Straight away this meant 3 things had to be done. Change the manifold and compressor pipe and make a new dump pipe.
The existing manifold was steam pipe so cutting off the 14B flange and making a T2 flange then welding it was pretty simple. Same went for the pipe that had to be adapted to the compressor housing.
The dump pipe was the next step. Using a standard one wasn't an option due to the angle at which it sits (directly onto the drive shaft). Modifying the cast one successfully wasn't really and option. So in true D.I.Y extreme mode I decided to create one from scratch. Now I only use a mig when welding and my joins wouldn't win any competitions but don't you know that utilitarian is the new sexy? Haha. I made it a front pipe to save myself making another flange because by this time I was sick of working with 8mm and 10mm thick steel.
They say I looked like a power ranger...
It all went back together and spent a few hours lining everything back up. The walk through thread on timing a MK1 was absolute gold. Without ever even touching a VW before it made it child's play.
Before I could really get to firing it up and and hoping for the best a package arrived.
For the $450 odd price tag I really couldn't complain.
