Results 1 to 10 of 15
Thread: Greasykitchen's compendium of potentially stupid Mk1 Golf questions
    Jan 2008
    Surrey Hills, Melbourne
    I have a bunch of questions so I though I'd keep 'em all in one spot. I'm fairly mechanically inept:
    1. What is involved in replacing the vent windows with ones from a cabby? I get sick of gluing up the current ones.
    2. There's a noise coming from my front left wheel, not a high pitch squeak or a low rumble, but sort of in between. Only at some speeds and even does it when the engine is off (car rolling). Wheel bearing? Something else. Are wheel bearings easy (ie cheapish) to replace?
    3. The steering wants to pull a little to the left. Last service said the right hand tie rod needs to be replaced. Might these be connected? It could just need a wheel alignment (not had one in a while, new tyres recently). Maybe wearing ball joints?
    Thanks in advance.
    '76 Mk1 Golf - Gone!
    '05 Mk5 2.0 FSI Sportline
    Jun 2006
    Orange NSW
    Quote Originally Posted by greasykitchen View Post
    Sounds like a Wheel Bearing to me. They're not too bad on a Mk1 to do. If you're not confident and haven't got someone to give you a hand though, i'd pay a GOOD mechanic to do it for you..
    If the RHS tie rod end needs replacing it would want to pull right if it was that causing a problem.
    Does it do it on the highway or just on a convex suburban street? Cars with veer (not pull) left on a convex street because they want to go to the lower side of the road (damn physics). If it is pulling left, it probably just needs a wheel alignment and you may aswell got your tie rod end replaced while you're at it because it's a bit pointless otherwise.
    Hope that helps.
    Jan 2008
    Thanks. It's due for a service so I'll get the VW blokes who've been servicing to do the bearing.
    As for veering vs pulling left, I'll have check tomorrow. I only really drive on suburban roads. It's not too bad - subtle but noticable and didn't use to do it.
    Perth. WA
    Wheel pulling left and noisy bearing probably caused by camber being set incorrectly, or belting it out of alignment in a pothole. The bearing life on the front axles is directly proportional to the accuracy of the wheel alignment ( camber and toe settings) I have found over the years. Adding wheels with huge offset ( low numbers in the case of a MK 1 ) will also minimise bearing life.
    Hope it helps, general observation from owning Mk1's since 1978.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Jan 2008
    Thanks. No off-sets or non-standard wheels, so it's just normal wear and tear I guess. It hasn't had a wheel alignment in the time I've had it so it's probably overdue for it. Would a place like Bridgestone do good alignments? There's one near work so that's very convenient. Getting the car to my mechanic for the other stuff on the other hand is a pain...
    Cheers for the input.
    Jan 2008
    Right, the thing with the veer/pull is: I have to have the wheel a bit to the right to go straight. It's a gentle pull to the left, not as dramatic as when I drove my parents' Camira (!) recently when it really pulled to the right (as in towards oncoming traffic)
    The golf's steering has gotten a bit sloppier/less responsive lately - it used to be really tight and handle great. Worn tie rod here?
    Jan 2006
    Ballarat, Victoria
    Choosing a wheel alignment place
    When getting wheel alignment on a Golf I have often had to work hard to convince them that the camber is adjustable. I have developed the habit of quizzing them on what they are capable of adjusting - one Bridgestone place only felt confident to set the toe - and I always ask for a readout of alignment before and after.
    Despite all that, my last wheel alignment failed to get it right despite numerous returns - in the end they blamed the car.
    Jan 2008
    Thanks. That's a bit poor, blaming the car. A poor workman and his tools, and all that...
    I don't know what the ideal camber and toe in/out is for a golf.
    So, anyone in Adelaide recommend a wheel aligner?
    Chairs
    May 2006
    Adelaide South Australia
    I have had good result from Kevin Kenny Tyre plus on Muller road, Greenacres.
    I reckon he knows what he is talking about & cost $45 for 4 wheel check & toe in adjust.
    He gives written report on alignment, before & after adjustments.
    Numerous Mk1 Golf diesels
    Jan 2008
    Quote Originally Posted by jets View Post
    Thanks, and not too far from me either I think.
