Sounds like a Wheel Bearing to me. They're not too bad on a Mk1 to do. If you're not confident and haven't got someone to give you a hand though, i'd pay a GOOD mechanic to do it for you..
If the RHS tie rod end needs replacing it would want to pull right if it was that causing a problem.
Does it do it on the highway or just on a convex suburban street? Cars with veer (not pull) left on a convex street because they want to go to the lower side of the road (damn physics). If it is pulling left, it probably just needs a wheel alignment and you may aswell got your tie rod end replaced while you're at it because it's a bit pointless otherwise.
Hope that helps.![]()
