carbs, dont ya just love em...:duh:
From the angle of the pic, that tube out the backside of the carb is the connection for the distributor vacuum advance,
Sounds like you have a few parts missing from the internals if its still bleeding fuel after turning off. check the bypass shut of solenoid for operation ..
As for the headlight dip problem, its more likely to be a knackered column switch...
HTH
Grant.
Lots of MK 1 Scirocco's...
Cheers,
Grant...
