Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 74
Thread: Gordie's MK1 GTI
  1. #41
    Quote Originally Posted by huskone View Post
    Nice seeing it in good hands! Looks like you still havent noticed the bend right lower control arm! Thats why the steering wheel of center and it pulls a bit to the side.
    Had no idea hah, got another wheel alignment done the other day, I have noticed it slightly pulls to the left. Will sort it out
    Audi S3 8L - Stroker GTX3582 700bhp+
    Golf GTI 1980
    Golf GLS 1979
    www.facebook.com/etunersmotorsportau
  2. #42
    Winton was super fun, was quite surprised how well the golf handled the track. Managed a 1:45.52 for the day
    Came 12th overall for the day, pretty happy!
    Here are the results - Result
    Will be out again at Winton on the 14/03 for labour day.
    Golf GTI 1980
    Golf GLS 1979
  3. #43
    Cool action pic from Winton recently.
    Golf GTI 1980
    Golf GLS 1979
  4. #44
    Nov 2014
    How in the new surface?
  5. #45
    Jul 2011
    That last shot looks good. Just keep an eye on the steering rack mounts running those fat semis. From what i understand, they tend to snap your steering rack clean off
  6. #46
    Quote Originally Posted by Notso Swift View Post
    Very smooth, don't think it would of played much of an impact on overall PB!
    Quote Originally Posted by MarcusAurelius View Post
    Thanks for info! Will look into upgrading it when motor is out this Winter.
    Golf GTI 1980
    Golf GLS 1979
  7. #47
    Been busy getting the car ready for its next track day ( which was yesterday )
    - New rear discs with new bearings and QFM racing pads, along with a camber shim with brought out the rears to -1.70 degrees of camber.
    - On the front I upgraded the brakes to 280mm using the G60 disc and VR6 calipers, QFM racing pads aswell. I also got a hold of a flipping the tie rod ends with the help of my dad using a magnetic drill! Sandblasted the hubs and painted them after.
    I got around installing the Ground Control camber tops too.
    Camber is around -3.95 on the front, has made a big difference in corner speed and grip, very happy! I flushed the whole system with racing black fluid and gave the engine a service. Flushed the coolant system with some racing penrite coolant which actually help alot on the day keeping the temps down.
    Got a cool photo by a friend while it was getting wheel alignment at MTN garage.
    Race day didn't go so well, car was would start misfiring after the engine got heated up. I managed to find some new plugs locally and did a one clean session out of the day then the problem came back! Think I'm in for some new NGK plugs, proper racing leads and a new dizzy rotor and cap! Hopefully that will sort my issues out
    Golf GTI 1980
    Golf GLS 1979
  8. #48
    Jan 2010
    Melb Westsideeeee
    "Got penrite coolant which helped keep temps down heaps"
    "Car over heated"
    Hahahaha. You did well over the weekend man, gripped the corners very well!
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
  9. #49
    Quote Originally Posted by 16v_kid View Post
    I think I can see how you can improve your power to weight ratio.
    Wear lightweight racing thongs.
  10. #50
    May 2010
    Richmond, VIC
    Alex would be proud
