Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 74
Thread: Gordie's MK1 GTI
  1. #21
    How low is your car?
  2. #22
    Nov 2014
    More relevant is the camber (and camber change, be it bump or castor) The closer to vertical the better for transferring the force straight through.
    Unless you are racing and hitting things they will be fine, the clubGTi failures (and it is not like thetre were 100's) were all on track cars, just inspect them as part of your normal (which in a Mk1 is regular!) service schedule
  3. #23
    Feb 2013
    Melbourne SE
    Quote Originally Posted by Notso Swift View Post
    I thought the main problem was that failure was impossible to predict. Even upon inspection they can appear to be fine but really be on the verge of failure. I was under the impression that they required an X-ray to determine the extent of any microscopic cracking that can occur.
    They are illegal for a reason, which is why I would never use them, and would avoid driving next to or in close proximity to someone who was using bolt in ball joint extenders.
  4. #24
    Are the ball joint extenders needed on this car?
  5. #25
    Perth. WA
    Biggest hassle is the basic design of the extender itself, the 17 mm spigot dia is what locates and carries the load, the larger dia is to incorporate the female socket for the 17mm ball joint shaft ( hence larger outside diameter on that section). So to machine it up you get the smaller spigot protruding from the round larger dia with a radius in the corner ( standard practice ) however once the 4140 is heat treated it creates an area of higher stress concentration in the radius for micro cracking to emanate from, add the stresses from use. With attempting to weld it there is first the issue with welding thru heat treatment, underbead cracking and residual stress from the welding op itself. Better option if you have to use them is to just bolt them up and perform a regular inspection as mentioned. Magnetic particle inspection is the procedure you need use for checking the extenders, or at the very least dye penetrant inspection.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  6. #26
    Oakleigh VIC
    Quote Originally Posted by roccodingo View Post
    Yep. I use them them on the racecar, but mine are 19mm and have a big radius. They were part of a batch done by one of the experts over at CGTI. No issues so far and I've jumped it off plenty of ripple strips.
    Regular inspection is key. Mine get checked after every raceday, so every 50km or so. That's a bit of an overhead for a street car.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  7. #27
    Thanks for all the info guys! Will keep an eye on them on a regular bases, so far so good! Front left top mount is making an annoying sound so think ill be installing a pair of Ground Control adjustable camber tops. These silver project top mounts didn't last long, I need 4000km on the car since I got it..not sure how many km ex owner did with the silver project top mounts.
    Here's a pic of a few weeks ago with George's mk1 - fun night having a few runs on the hwy!
    Audi S3 8L - Stroker GTX3582 700bhp+
    Golf GTI 1980
    Golf GLS 1979
    www.facebook.com/etunersmotorsportau
  8. #28
    Jan 2010
    Melb Westsideeeee
    I might have some hi res pics of that night, will have a look dude! When are we hwy'ing again haha.
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
  9. #29
    Jun 2014
    looks mint gordie!
  10. #30
    Jan 2015
    Brisvegas
    Beautiful!! I want one!!
