Motul Gear 300 is about the best non-LSD specific oil I've used. Motul Gear-FF-LSD is the choice if you have an LSD, though.
Redline Heavyweight Shockproof is also pretty good in an older trans. The lightweight version is ok in a newer one too![]()
changing the oil in my box, as it's been getting a hard time.
any recommendations as to a quality gearbox oil to suit 020 5-speed?...don't mind spending money on the important bits.
thanks folks.
78 2-door 1.8 KR 16v - twin dellorto's
Castrol VMX 80
Mild extreme pressure gear oil with special viscosity stabilisers to overcome shift problems. Recommended for use in transaxles of most front wheel drive vehicles with a transverse engine and manual transmissions experiencing low temperature shift problems. SAE 75W/80, API GL4.
