Results 1 to 5 of 5
Thread: Good Quality Oil?...Recommendations
    Mar 2009
    changing the oil in my box, as it's been getting a hard time.
    any recommendations as to a quality gearbox oil to suit 020 5-speed?...don't mind spending money on the important bits.
    thanks folks.
    78 2-door 1.8 KR 16v - twin dellorto's
    Aug 2005
    Motul Gear 300 is about the best non-LSD specific oil I've used. Motul Gear-FF-LSD is the choice if you have an LSD, though.
    Redline Heavyweight Shockproof is also pretty good in an older trans. The lightweight version is ok in a newer one too
    Mar 2009
    Quote Originally Posted by Valver. View Post
    thanks! um what about if there is a limo kit installed in the diff but its not a full lsd?
    Aug 2005
    Quote Originally Posted by dubmc View Post
    You can still use Gear-FF... In fact, you can run it in stock trans altogether. A lot of the Jap crowd run it in standard transmissions It's just a lot dearer than Gear 300, which is damn good anyway...
    Aug 2006
    Melbourne VIC
    Castrol VMX 80
    Mild extreme pressure gear oil with special viscosity stabilisers to overcome shift problems. Recommended for use in transaxles of most front wheel drive vehicles with a transverse engine and manual transmissions experiencing low temperature shift problems. SAE 75W/80, API GL4.
