Results 1 to 10 of 10
Thread: Going efi soon tell me about surge tanks
    sydney/ cessnock
    going to upgrage my mk1 project two 16v and i have heard that u cant use the standard fuel tank with out a surge tank, i heard the other option was to get a gti / desiel tank but in the gti cabrio i just sold i already had some trouble when doing long hard right turns with fuel starvation. i dont think the baffles are good enough. could anyone with conversion experience give me some clues (please if u have no clues dont respond)
    owned a number of mk1 golfs have a collection of spare parts project golf is a 78 2 door
    Jul 2005
    Done quite a few injection conversions on mk1s and the only time fuel starvation is a problem is when you're out of fuel.After all the dsl/gti tank worked for every standard injected car VW made.The fuel tank in my caddy is the standard dsl one and it feeds the 1.8t without any problems.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    20v kit car Guest
    had the same prob in my 85 gti cabrio..even put in a new lift pump...fuel starve on hard cornering...think you are in the right area with the baffles ..never got to the bottom of it. as pete says most other converted cars using diesel tanks dont appear to suffer the same prob...got me stumped!!!!! surge tank is always a safe bet..on anything driving hard...cheers steve.....wasn't a black gti cabrio you owned was it?
    Camden, Sydney
    I think diesel tanks and GTI tanks are slightly different. I heard that the diesels had better baffles, so maybe your problem is limited to those mid model cabrios. They were basically running Mk2 everything, but a modified Mk1 tank.
    I`m using a diesel tank in my Mk1, 16v easier to get in Oz.
    Golfwise Guest
    Use a lift pump as in later Cabrios,better than taking the tank out ??????
    sydney/ cessnock
    reply
    the gti and diesel tanks have the same part no. according to brians computer so cant see them being different. golfwise are u suggesting standard tank with lift pump into surge tank sounds like the easiest solution to me. unless someone local has a diesel tank for sale. thanks all for responce
    Golfwise Guest
    Fuel tanks
    VW stopped using the old diesel/GTI tanks as far back as 1984 and used a normal style one with a lift pump.There is a lot of engineering brains at wolfsburg, why reinvent the wheel I say.
    I changed many a tank for the diesel ones in the past but never again.
    Go lift pumps !
    syncro Guest
    Re: Fuel tanks
    Quote Originally Posted by Golfwise
    Go lift pumps !
    The lift pump tank is different again.
    171 201 075P NA Tank
    171 201 075Q FI Tank
    151 201 075B FI Lift Pump Cabrio Tank
    I am not sure but I think that the fuel lines may be larger in FI tanks.
    Golfwise Guest
    Fuel tanks
    Always use bigger fuel lines and the diesel ones are good to use too.
    Camden, Sydney
    How big a fuel line 8mm 10mm?
Similar Threads
  1. Biodiesel
    By flightlessbird in forum Diesels
    Last Post: 04-09-2006, 07:23 PM
