One is a return line. Assuming that your car still has the original mechanical pump. The only fuel you'll get to the carbie is when you crank the engine over, which in hand cranks the mechanical fuel pump. It shouldn't take too much to get some fuel through.
If you can get the filter off and use a plastic syringe to squirt a bit of fuel into the carbie that could be enough to get it running for a few seconds while the mechanical pump picks up and delivers fuel through the lines. And theres always the Aerostart/start ya b@st@rd spray instead of squirting petrol in it.
If she doesn't fire check it for spark. But I think you already did can't remember.![]()
