Yes indeed you can remove the gearbox with engine in-situ. I would have a Haynes Manual handy so you can refer to it and plan your work.
Also make sure you have a clean, clear surface with containers for all the bits you plan to remove.
raise the front of the car with some sturdy car stands so there is at least enough room under the front to remove the box from under the car.
Remove the gear linkages, clutch cable, speedo cable and wiring to the reverse switch, remove the starter motor, flywheel guard (if it's still there) then with your trusty trolley jack or a block and tackle winch supporting the engine only, release the gearbox, front and rear engine mounts,
Disconnect anything that impedes this movement (eg: radiator hoses etc) and lower until you can physically remove the box from under the car. Use another jack to hold the box in place as you undo the bolts that go around the box connecting it to the engine block, slide it out and hey presto gearbox removed.
While you are at it, replace the clutch, and pressure plate, and if time permits have the flywheel machined to create a nice new surface for the friction disc.
You will need a 5 speed linkage kit, and make sure you empty the replacement box of oil before putting it all back together. Some like to fill the box while it is out, but just another leaking liquid and some more weight. Put some good gear oil in the box once all re-assembled.
Have fun!
