Results 1 to 10 of 11
Thread: Gearbox Replacement
    Jun 2008
    Hobart, TAS
    Gearbox Replacement
    hello guys and girls,
    Going to replace the gearbox in the mk1.
    Want to know if this can be done without taking out the engine?
    What gear will I need to do it and how long should I allow to do it?
    Also, if I was to upgrade to a 5 speed, is there anything else that will need to be changed for it to work (i.e. linkages, etc)?
    It's been too long with a noisy gearbox, time to get a quiet one
    cheers,
    Michael
    1979 Mk1 Golf GTi
    1994 Mk3 Golf VR6
    Dec 2007
    Somewhere in Melbourne, Victoria
    Smile
    Quote Originally Posted by SpeciP3 View Post
    cheers,
    Michael
    Yes indeed you can remove the gearbox with engine in-situ. I would have a Haynes Manual handy so you can refer to it and plan your work.
    Also make sure you have a clean, clear surface with containers for all the bits you plan to remove.
    raise the front of the car with some sturdy car stands so there is at least enough room under the front to remove the box from under the car.
    Remove the gear linkages, clutch cable, speedo cable and wiring to the reverse switch, remove the starter motor, flywheel guard (if it's still there) then with your trusty trolley jack or a block and tackle winch supporting the engine only, release the gearbox, front and rear engine mounts,
    Disconnect anything that impedes this movement (eg: radiator hoses etc) and lower until you can physically remove the box from under the car. Use another jack to hold the box in place as you undo the bolts that go around the box connecting it to the engine block, slide it out and hey presto gearbox removed.
    While you are at it, replace the clutch, and pressure plate, and if time permits have the flywheel machined to create a nice new surface for the friction disc.
    You will need a 5 speed linkage kit, and make sure you empty the replacement box of oil before putting it all back together. Some like to fill the box while it is out, but just another leaking liquid and some more weight. Put some good gear oil in the box once all re-assembled.
    Have fun!
    1991 Golf GTI Manual - Tornado Red (Little Red Wagen)
    1998 Golf Cabriolet Manual - Black Magic Pearl (aka Rommel's Panzer) Deceased/written off
    1993 Golf Cabriolet Manual - Alpine White (aka Hitler Youth Wagen) Deceased/written off
    1976 Golf LS Manual - Bronco Brown (aka Roadrunner) Deceased/worn out
    Apr 2006
    Hobart,Tas
    The gearbox mount is totally different.
    foc64 can now make them and they look a treat
    Jun 2008
    Hobart, TAS
    thanks Paulie, sounds good.
    got myself a haynes manual so shall be looking at that
    Thanks Andrew i'll pm foc about a mount.
    cheers
    1979 Mk1 Golf GTi
    1994 Mk3 Golf VR6
    Jun 2008
    Tassie
    Quote Originally Posted by gtimk5 View Post
    Andrew does that mean I'll owe you a spotter's fee???????????
    Chris
    Apr 2006
    Hobart,Tas
    Hey Chris!!!
    Get out in the workshop and keep building mate, No time for bludging, will give you my bank details next time
    Andrew
    Jun 2008
    Hobart, TAS
    haha! you'll have to start advertising.
    foc you have pm
    1979 Mk1 Golf GTi
    1994 Mk3 Golf VR6
    Perth. WA
    Undo the CV joints at the transmission flanges too, otherwise its going to be a bugger to remove.
    On the 5 speed box, you may need to swap the flanges to match your CV joint size ( 90 or 100 mm ) the haynes may show that proceedure...And as mentioned, your better of getting all the five speed shift parts as there are a few differences.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Dec 2007
    Quote Originally Posted by roccodingo View Post
    oops my bad-they do need to be removed. Good pick-up there roccodingo. When you do it by instinct sometimes the verbalising of the task is a bit hard.
    Pity help the people I train!
    Aug 2009
    Brisbane Sth
    I'm doing it right now
    I just got out from underneath the MK1, the box is back in and by tommorow afternoon I will be able to give you a wrap up on the whole sorry tale
    look here
    http://www.vwwatercooled.org.au/newf...t=34686&page=2
    Spark ignition is a threatened species
    Biodiesel is the best emission control money cant buy
    MK1 5 door Mexico Beige 5/79 Golf GLD 1.5
