You've got it in one. The oil runs along the push rod that activates the clutch past a brass bush and a rubber seal and then gets onto the clutch plate. I hate to tell you but I am 99% sure that you will be up for a new clutch.
When you replace it make sure you replace the brass bush and the I always used to put 2 of the seals in whenever I put a new clutch in.
