Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Gearbox oil leak....
    Mar 2007
    South Brisbane
    I did fill the box up via the speedo sharft not alwas smart idea just this arfternoon i got the right sized bit to undo the fill plug which was rather Hard!!! to get off anyways only a bit come out so it was overfull from the begining, now ive done that went for a spin no visable leaks after a run now still clutch is slipping but thats expeceted, anyways how hard is it to replace the push rod bushs and or main shaft?
    brisbane
    thread from the dead, I have a leaking gearbox and from reading this I strongly suspect its an input shaft seal that need replacing...
    020seal
    oil is dripping from the bell housing so guess that means oil is getting past the shaft seal. the main engine mount is stuffed too so thinking I may as well tackle all this at once...
    don't suppose anyone in brissie has an engine crane they'd like to hire out for beer money please?
    Adelaide hills, SA
    Quote Originally Posted by guile View Post
    You can buy these very cheap these days, from places like SuperCheap Auto.
    brisbane
    thanks for the heads up mate, its just I have nowhere to keep one if I purchased something...
    i'm now thinking about tackling the issues separately, drop the gearbox from underneath the car and then try and do the engine mount with the motor still in (although I've heard this is difficult)...
