Results 1 to 10 of 16
Thread: gearbox oil leak
    Aug 2011
    brisbane
    gearbox oil leak
    i need to change the inner cv boot on the passenger's side. is it normal for gearbox oil to leak from a split boot, i thought the flange was sealed fro the box?
    There shouldn't be any leak but you might have some oil that's seeped out over the years.
    Give the flange a wipe down and see if it's leaking. If it is you've got a problem.
    Aug 2011
    brisbane
    the boot's torn completely round, and there is no grease at all, just a pool of oil!
    Gosford Central Coast NSW
    well not quite true, there is an oil seal on the inside of the gearbox driveshaft flange, and these can pretty easily be damaged by over-compresson of the inner cv joint - the end of the driveshaft will punch into the seal and thats it. You can get these easily and cheaply.
    Also, over a long time, some greases will decompose and the lighter oils which are normally trapped in the grease can seperate out. See this plenty of times, you open up a cv boot and you get a pool of oil and some thick black/brown gunk (thicker than normal grease). I'm pretty sure if you use proper cv joint grease this doesnt normally happen, but a lot of people think grease is grease.
    Whenever I take out a driveshaft, I always make sure to check the inner seals for damage and change them if necessary. They are so cheap I keep a stock of a couple just incase.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Aug 2011
    brisbane
    thanks for the info. so if i drop the drive shaft, will it be obvious to see if the seal has been damaged?
    If they are anything like the ones on my MK2 it should be easy to see. Wipe off all the oil and grease and look for any damage. The seal is a large metal cap with rubber around the edge and a press fit. Might be different though, 1 of the 4 I've taken off today was a metal cap that was screwed on, needed an allen key to take it off and it was so tight I gave up.
    Aug 2011
    brisbane
    thanks paul, just have to work out how my son gets the jack under the car, the sump is only 50mm of the ground
    Aug 2011
    brisbane
    well, iv'e taken the drive shaft off. when i removed the 6 screws and pulled the shaft back, a heap off gearbox oil dripped out.
    there is absolutely no sign of grease ever being in there, so can only assume it was full of oil. the cap is on the inside of the flange.
    beats me how, if it was filled with oil, how they got it in there?
    Perth. WA
    New CV boot and 90 G of moly disulphide grease then pop it back in. Check the outer joint for lube and boot condition and do it while you got the assembly out.
    Be done by morning smoko .....................................whats next ??
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Aug 2011
    brisbane
    Quote Originally Posted by roccodingo View Post
    thanks, you answered my next question on how much grease to use!
    still can't explain why it was full of oil and no grease?
