Results 1 to 8 of 8
Thread: Gearbox golf cabrio 1990
    Mar 2008
    hi everyone,
    really very in this group, i was hoping to get some advise...and help!
    problem: Was driving nicely when the gearbox got jammed in 3rd gear....impossible to go to 4th, 2nd or neutral. Clutch seems ok after a first NRMA quick look at it during towing...
    Tried to force it into neutral while engine off, with and without clutch...that hapened once and was able to desengage it no issue since then
    took the car to the garage....which obviously declared the gear box gone (as you do) without inspecting it (told them not to put it down as it would cost a fortune in labor)
    so I guess the question would be....has anyone experience that before and what was the damage....the price being quoted for a secondhand one is way beyond by budget....I am looking at buying a second hand one from wreckage etc...Anyone knows about 1 Golf 1990 cabriolet 's GEARBOX?
    and also any good small trustworthy garage in sydney to do the job???
    Thanks heaps for you help in advance...
    Nov 2005
    may i suggest to you the shifter linkages, the bushes are most likley shot mate, if there is no rattle or humming noise while driving, its most likley your best bet, ive gone through a cabrio box or 2 and its usually due to shyte linkages
    cheers
    wabit
    Gosford Central Coast NSW
    hey mate,
    gearboxes go occasionally, and certainly its possible yours has had it - it does happen. if it isnt the shift linkages (easy to check, just disconnect the shift rods at the gearbox and see if you can select any gears by hand) then you might want to find another box. 4 speeds are cheap (read givaway) items and 5-speeds go for anything between 400-1000 bucks depending on age, condition and rarity.
    golf loon on this forum might be able to help you out. he wrecks seat/golf.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Boronia VIC
    I had exactly this happen to my car. The gearbox had to come apart twice before it was fixed. The best advice I can give you is to grab another box and slam it in there.
    Pete
    Orange NSW
    I had a similar problem on one of my MKIs, except I could get all gears except reverse. New bushes and it was fine. Hope its like that with yours fabs.
    77'Golf
    Camden, Sydney
    Could wellk be linkages mate, get that checked before you spend $$s on a box.
    My company Camden GTI has a specialist workshop at Campbelltown and will give you free advice and a cheap gearbox if needed. 0423 051737 during work hours.
    Matt
    Oct 2006
    Perth WA
    My Mk2 Gti did this, it turned out to be the clutch, the springs on the pressure plate broke.
    2.0L 16v Audi 80 - Project
    3.0L 30v Audi A6 quattro - Daily
    Mar 2008
    thanks heaps everyone for the replies !
    Matt, will give a call this week.
    cheers again guys
