Hey guys, I have in my possession a 020 5 speed box (at least pretty sure it is, found 020 stamped on the bellhousing), which I am planning on chucking in, however i cant find any info regarding what clutch i need.
The car will be running a 1.6.
Will a standard 1.6 4 speed clutch fit? Or is the clutch a different size?
Secondly, if a standard one does, will it be strong enough? Plan on running a 45dcoe with extractors, maybe cam later down the track.
It's the last thing i have to buy before i can start piecing my car together. Please help![]()
The Baltic Bruiser™
your standard clutch will fit no probs, but if you're going for more power than before you might try getting a gti clutch setup or something newer with 020 setup... some mk3's had 020, mk2's are 020... so theres plenty of stuff around.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
