Results 1 to 10 of 13
Thread: Gear shifter troubles. HELP PLEASE!
    Eastern suburbs of Melb
    hey guys in my mk1 underneath the car is the rod that comes from the front onf the car then connects to the shifting rod...
    have any one got pictures of what it should look like under there?
    I have it all hooked up and everything bar reverse works and i have to push the shifter down to get it into 1st and 2nd.
    Stu
    Aug 2007
    Mate generally you need a special tool to line up the gearshift, but sound like you also need a ball and socket kit mate to rectify this issue. Ask your local dub parts or OEM supplier for a ball and socket repair kit.
    Alba European
    Jun 2007
    Country Victoria
    Shift Adjustment
    Sound like the linkages need adjusting. for a how too, check out this site.
    www.cabby-info.com/
    in "community" (bottom left of screen) click on "links & resources" in the middle column click "Bad habit Rabbit" then click "checking and adjusting the shifter" hopefully this will help.
    Note a "Shift Kit" with all linkages and bushes from the USA will cost about $16.50 US. VW Australia quoted $50.00 for one linkage....
    New linkages are meant to cure 99% of all gear shifter problems, from what I have been told. Which is why next week I have my cabby booked in to have new engine mounts, plus the new linkages and bushes installed.
    Michael
    Dec 2007
    Somewhere in Melbourne, Victoria
    An old rule of thumb is to use a matchbox and to centre the linkage in the housing below the floor (front to back of the car) and the space between the selector shaft (gearstick coming through the floor) and the housing is the thickness of the matchbox (striker side). This is done in neutral. When in doubt refer to the old trusty Haynes Manual. Good luck
    ok i will give it a shot thanks mate
    Jan 2006
    Ballarat, Victoria
    How did you get on?
    I would expect it to be a straightforward fix to use the Haynes manual or matchbox method.
    Jul 2005
    In the old days it was the thick side of a cassette, but I guess matchboxes will be around forever.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Gosford Central Coast NSW
    grab a helper, put the car on ramps and get under there with a 13mm socket.
    once you ort it out in your head how it all works together, setting it is easy.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    thanks man
    i got under there for ages it seems to be alll hooked up correctly but still no reverse...
    Jun 2006
    Orange NSW
    http://stores.ebay.com/Mk1-Autohaus_...Q3amesstQQtZkm
    Check this guy for Mk1 NOS stuff. got a shifter kit from him for US$16.50, aswell as a heap of other stuff. Well recommended.
