Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Gear shifter troubles. HELP PLEASE!
    Eastern suburbs of Melb
    http://stores.ebay.com/Mk1-Autohaus_...Q3amesstQQtZkm
    Check this guy for Mk1 NOS stuff. got a shifter kit from him for US$16.50, aswell as a heap of other stuff. Well recommended.
    ummmm spammmmer in our midst
    Jun 2006
    Orange NSW
    Quote Originally Posted by thestu View Post
    What do you mean dude?
    Jan 2006
    Ballarat, Victoria
    thanks man
    i got under there for ages it seems to be alll hooked up correctly but still no reverse...
    The adjustment is in the gearchange shift rod clamp. It clamps the shift rod onto the selector lever. Loosen the clamp and rotate the shift rod until there is the required clearance between the shift finger at the end of the gear stick and the stop plate. Clearance for a 4speed is 20mm, 15mm for a 5speed. This, however, may not make much sense without diagrams to identify the various components.
    If you'd like a hand, I'd be happy to help out.
    I'm often travelling thru the Eastern Suburbs, so I may be passing by. Send me a PM with how to contact you if you'd like a hand.
    Paul
