Results 1 to 3 of 3
Thread: Gear linkage Help
    Aug 2012
    Blackmans Bay, TAS
    Gear linkage Help
    Alright, so I replaced the inner gearbox side cv in my mk1 last week (engine is a 1.8 from a mk2 gti) everything went pretty smoothly, car drives. But ever since swap I haven't been able to select first gear.... I've plays with linkages (under instruction from Gipson) trying to manually select first then set linkages from there, but I continue to select (what I assume is third gear, due to the fact that at high revs I can get car to move forward, so I'm guessing its not fifth).
    Basically I need advice. Is there something I could have done/not done/ f***ed up while I was replacing cv that could have caused this. Or is there something I'm not doing to correctly set/adjust the linkages....
    Feb 2006
    Perth Western Australia
    they can be a right bastard to set properly, you need two people, one the continually get gears, the other to adjust the linkage on the spigot
    77 Golf tarmac rally
    89 porsche 911
    80 Rabbit 4dr
    11 mk1 and 2\'s in various states of undress
    KEEPING THE BIG CUBES IN THE REAR VISION MIRROR
    Aug 2012
    Blackmans Bay, TAS
    I actually, finally managed to fix this today! Took many MANY frustrating attempts, but it's now all good.
