Results 1 to 9 of 9
Thread: Fusebox numbers
    Sep 2009
    Chillaxing in Tas
    Fusebox numbers
    My fuse box Says 171 941 813 A on it
    Found one thats same number but B instead of A...
    whats the difference? if any
    Dan
    <space for rent>
    Feb 2006
    Perth Western Australia
    the B and C fuseboxes are for the carby golfs where as the A box is for the fuel injected cars as it has extra pins for the 5th plug. The B and C fuseboxes only have 4 plugs at the back mate. And no a B fusebox will not be correct for your car as the wiring is slightly different and requires some fiddling around.
    77 Golf tarmac rally
    89 porsche 911
    80 Rabbit 4dr
    11 mk1 and 2\'s in various states of undress
    KEEPING THE BIG CUBES IN THE REAR VISION MIRROR
    Sep 2009
    Chillaxing in Tas
    mines a carby car, so it seems i got the wrong box in anyway
    Will my current loom fit up with the B fusebox? seeing as my car is carby and all
    <space for rent>
    Feb 2006
    depends, does your harness have 4 plugs or 5? the B &C boxes have no pins in one of the slots whereas the A's have pins in all 5 slots for 5 plugs
    89 porsche 911
    80 Rabbit 4dr
    Sep 2009
    Chillaxing in Tas
    ahhh not to sure to be honest,
    think there was a black blue and yellow plug, and 2 white ones... so 5.. Ill double check tomorrow when its daylight
    <space for rent>
    Perth. WA
    Pretty sure the 5th plug is for the early cars diagnostic port Luke, as all my injected cars run C versions. All are 79 or later build dates
    there are some differences in the pin outs from the 'A' version to the 'b and 'C models.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Sep 2009
    Chillaxing in Tas
    mines a 79, and was diesel. dunno what year the petrol loom was pulled from though
    <space for rent>
    Don't need to ask any more questions
    http://www.vwwatercooled.org.au/f24/...uff-52943.html
    Exactly the same part.
    Sep 2009
    Chillaxing in Tas
    Already bought it
    Its good to know the differences for future reference though.
    just checked my plugs, black and blue plugs are for the dash loom, yellow for the rear lights harness, one white one for the headlights and front indicators, and one white one for Coil wires, reverse light switch, temp senders ect.
    <space for rent>
