No fuses for engine/spark.Originally Posted by XXX-1.8T
Hi as u know I had probs with my brake lights it turns out it was the fuse not in properly.
Then when i checked again today they werent working so i mucked around with it and got them to work.
Now the car wont start and if it does it feels like its running on 2 cylinders
The car idles at 500rpm when it used to idle at 950. The car goes like a snail so im guessing i stuffed up a fuse
Which one would it be?
Which one controls engine or spark?
really pissed
You might have bumped the vaccum hose off the ECU while you were under the bonnet? Easy to do!
Its a Mk1 Andrew.
I reckon a wire or a vacuum line under the bonnet.
Check aroiund the carby area.
But the K/jetronic has a vaccum hose to the box Loon. I bumped it off in a rally once. Idled ok but lost power. Correct me if I am wrong though.
No, sorry. I thought it was a gti!!! I stand corrected!!!!!
but i havent been under the bonnet
Ill check anyways!
checked under no pipes missing.
all sorted!!!!
Turns out my spark plugs were stuffed.
Must of been a co incidence with the fuse box probs cars all sorted now and go fanging must be careful of licence
Big thanx to Will (endlessmk1) for helping me out!!!
He Costa, is it still happening?
MY16 MKVIIR - Option: Folded rear seats mode.
MKI....#14....lost count.
