Results 1 to 4 of 4
Thread: Fuse allocation? numbers 1 - 15
    Mar 2006
    brisbane
    Question Fuse allocation? numbers 1 - 15
    Anyone have details what rating the fuses are in in the early fusebox? Over the years I'm sure mine have been mismatched.
    Probably a good thing to have correct and I think it may hold the key to my indicator troubles.
    PS i thought deleting a thread would actually delete it but its just there being useless and messing up the board, my bad.
    Gosford Central Coast NSW
    fuse - function - amps
    1 - low beam left - 8
    2 - low beam right - 8
    3 - high beam left and warning light - 8
    4 - high beam right - 8
    5 - heated rear window - 16
    6 - stop lights, hazard flasher system - 8
    7 - interior light, cig lighter, radio - 8
    8 - turn signals and warning light - 8
    9 - reversing lights, horn, engine electrics - 16
    10 - fresh air fan - 8
    11 - wipers, washer pump, int relay - 8
    12 - number plate lights - 8
    13 - right parkers - 8
    14 - left parkers - 8
    15 - radiator fan - 16
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Nov 2005
    newcastle
    one my recent build. the blinkers activated the light on the console and the parking lights but didnt activate the flasher relay or run the binker bulbs
    turns out it was a dodgy hazard light switch.
    might be helpful.
    TDI mk1 on the road!!
    Mar 2006
    brisbane
    perfect. thanks heaps.
