Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Full poly bushes on mk1
  1. #21
    Sep 2008
    Fitzroy, Melbourne
    I don't think it will be cheaper.. remember all of those prices are for single bushes and for most of them (except motor mount) require two.
    76' 2dr Kjet
  2. #22
    Jan 2009
    south west sydney
    how hard are these things to install?
    do you need special tools to press them in. i've heard of people using drill presses. is it possible to do without one?
  3. #23
    Boronia VIC
    The red ones are very easy, they're in two parts.
    The superpro ones take a bit of convincing but brute force and ignorance will win through.
    Getting the old ones out on the other hand......
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  4. #24
    Jan 2009
    south west sydney
    i would have thought theyd be brittle and just fall out.
  5. #25
    Jan 2006
    Quote Originally Posted by MiKe1_golf View Post
    The front control arm bushes take some pressing to get out, and it can be a little awkward to balance the A-arm in the press too. But it doesn't matter if you butcher the bushes in the process, you just have to get them out. The red poly ones go in easy. I honestly can't remember doing the rear pivots, I think its much the same as the front a-arm ones. They are the hardest 2 suspension bushes.
  6. #26
    Jan 2009
    south west sydney
    what about the engine mounts and steering bushes do they more or less require you pulling the engine out?
  7. #27
    Jan 2006
    You can get the mounts out without completely taking the motor out but the drivers side one is a bit of a pain. You have to lower the motor on that side from memory. If you're putting the poly inserts into the drivers or passenger side mounts you may have to replace the current mounts at the same time and that involves more pressing.
