Results 1 to 3 of 3
Thread: fuel and temperature gauge
    i started my golf up this morning and the fuel gauge starts rising as usualy then suddenly stops and falls and doest come up again.. i run it for 5 mins to check if it will come up again and nothing what the hell it was working perfect the otherday...
    Golfwise Guest
    Guages
    If you temp and fuel don't work its your voltage regulator situated behind your guage panel and is located by a small screw and has 3 prongs on it and is rather small.Replace as needed
    how much would it be?
