Results 1 to 9 of 9
Thread: fuel pump problems
    burnie,tas
    fuel pump problems
    fuel pump problems (i think?) my golf has been coughing and farting for bout a km then stop and wont go again have a play with the carbi and maybe the dizzie and away it goes again for bout 3 weeks and then it does it again. ive been told it could been the fuel pump
    1977 2dr golf gls (Gti look a like with 2e convertion
    1978 Golf Gti barn find
    2013 Amarok Highline daily
    2017 Golf wagon wife’s daily
    Nov 2005
    newcastle
    crap in the fuel tank maybe?
    could be stuff in your fuel tank.. my yellow mk1 had that problem and it took me ages to figure out i had something floating round in my fuel tank and every now and then it would block the fuel sender... thats after i had replaced my fuel pump without results..
    try blowing all the fuel back down the fuel hose if it happens again... or if you could be bothered, clean out your tank next time you're near empty...
    TDI mk1 on the road!!
    burnie,tas
    thanks i try that i taking the pump out tomorrow i ll drain the tank too
    burnie,tas
    fix the problem i think semi block fuel line blew it out hasn t miss a beat since well untill the throttle cable broke
    Jun 2007
    Eastern Suburbs Melbourne
    have a look at ur fuel filter too, Josh had a similarish problem we fuel delivery. he got a new fuel filter ($4) and snap, fixed. for $4 it could be worth it?
    i like volkswagens
    May 2007
    Sunny Perth! (and windy Perth too)
    Given me an idea - I have similar prob, car runs fine then just splutters out, usually when 1/4 tank or less fuel, have changed filter but not cleaned out tank. What best way to check fule pump?
    daaave
    burnie,tas
    Quote Originally Posted by pi22a View Post
    daaave
    that sound like stuff in the tank my boss tested the pump so i don t know how is done, as for the filter it was the first thing i changed
    May 2006
    Maroubra NSW
    Is it during longer runs that it coughs and splutters? If so, i'd think it would be crap in the tank. I fixed it by removing the little mesh filter which fits over the pickup line. It sucked all the remaining crap (after cleaning the tank out) into the fuel filter, but that way i could see it! (and duly replace the fuel filter).
    I had this problem for 2 months once. The car stopping on the freeway, and just out of the harbour tunnel, and countless other similarly inconvenient spots ****ted me to tears.
    Peugeot 306 XTDT 1.9 Turbo Intercooled Diesel
    1976 LS parts vehicle
    Used to have: Mk1 Swallowtail LS DIESEL!
    May 2007
    yeah happens after long runs (30min or so), filled it right up today and no problems at all, so I'm pretty sure its crap in tank! Another fun job to do this weekend,,,
