Sounds like you have the wrong relay, the early fp relays have an external 16amp fuse. Depending on whether the car has had the 'relay recall' done the relay will either be mounted on top of her fusebox (second position from left, I think) or on the fusebox itself, again second position in from the left. Both early and late relays will have 5 prongs.
HTH Gav
