Results 1 to 6 of 6
Thread: fuel and oil type?
    Aug 2011
    brisbane
    fuel and oil type?
    does the 8v use premium fuel and the expensive golf only oil, like latter models?
    May 2011
    Albury, NSW
    I just bought a new 1993 Cabriolet - 1.8 8v k-jet and it has a sticker under the bonnet that my 1991 one didn't have saying 91-93RON minimum or something along those lines. I've been putting 95 in mine for about the 3 times I've ever put fuel in, but that's purely because 95RON is standard unleaded in Europe they don't use 91 like the cars over here.
    As for oil I remember the Castrol I bought being like a pretty cheap version - it wasn't one of the newer ones that's VAG approved.
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    Aug 2011
    brisbane
    the sticker inside the fuel cap only says unleaded!
    I've always run 91 in my MK2.
    There was something on the ABC a few months ago where they recommended 91 for almost every car on the road. Obviously the high performance cars with high compression engines need 95 but the Cabby should be fine on 91.
    Paul
    Aug 2011
    brisbane
    all i could find on oil, was to use 10-40grade
    You can go thicker on older engines. Sometimes it can be more beneficial especially if the engine has done a lot of k's and has a bit of wear, keeps it quieter.
    You don't need expensive oils either. Anything from Supercheap or Repco will do.
