Results 1 to 10 of 17
Thread: Fuel cut problem...
    Eastern suburbs of Melb
    Fuel cut problem...
    Disclaimer: photo taken on closed private road actually was taken when the car was stopped!!!!!!!!!!!!!!!!!
    Jun 2006
    Orange NSW
    You're an idiot for posting that on a public forum.
    And my 4 door 1.7 would be able to go faster than that. I've never tried though.
    my diesels faster
    dude i was waiting for "your an idiot for posting that"
    then i was gunna post the next one
    me and jarred were doing 60 km/h when the speedo went psycho and went up to 160 and stayed there lol
    anyone know how to make the neddle go back to 0?
    Aug 2008
    SYDNEY
    I never believe speedo photos unless i see the tacho as well. even then im skeptical.
    as for your stuck speedo problem i think you your first step would be to take the cluster out.....thats what i'd be doing..
    cheers
    2008 POLO GTI - SOLD
    2005 MkV Golf GTI - couldn't resist
    Quote Originally Posted by AUC-05L View Post
    cheers
    BAHAHAH well i showed both!
    no kidding about taking it out...anyone got any idea how to actually fix these things?
    Oakleigh VIC
    Your engine is badly earthed and you have fused the needle return spring.
    Common issue. When there is no other earth on the motor the only return path for the current is up the speedo cable. Mechanics often blow up speedos this way if they've had the box or motor out and forget to re-attach the earth cable properly.
    You're going to need a new speedo. You also need to fix your engine earthing first.
    Lucky for you I've gots heaps of them
    Pete
    Pete
    ohhh wow! this solves lots of problems! do you know why my radio turns off when i put the clutch in? i have checked the cable and it doesn't go near any wires...
    also when the clutch is in the car won't start!!!!
    Oakleigh VIC
    Quote Originally Posted by thestu View Post
    Same problem! Your clutch cable is acting as the earth return. It's acting like a big switch when you engage the clutch and disconnecting the earth to your motor, at which point all that juice shots up your speedo cable instead.
    You need to fix your earthing!
    There should be a cable from the negative of the battery to the chassis and the gearbox mount. I reckon the chassis or gearbox connection is missing.
    Pete
    Pete
    ohh ok
    well when i put the new gearbox in i made a new connection for the gearbox mount but i uess its not working very well!
    will fix it after dinner and tell you what happens!
