You're an idiot for posting that on a public forum.
And my 4 door 1.7 would be able to go faster than that. I've never tried though.![]()
Disclaimer: photo taken on closed private road actually was taken when the car was stopped!!!!!!!!!!!!!!!!!
my diesels faster![]()
dude i was waiting for "your an idiot for posting that"
then i was gunna post the next one![]()
me and jarred were doing 60 km/h when the speedo went psycho and went up to 160 and stayed there lol
anyone know how to make the neddle go back to 0?
I never believe speedo photos unless i see the tacho as well. even then im skeptical.
as for your stuck speedo problem i think you your first step would be to take the cluster out.....thats what i'd be doing..
cheers
2008 POLO GTI - SOLD
2005 MkV Golf GTI - couldn't resist
Your engine is badly earthed and you have fused the needle return spring.
Common issue. When there is no other earth on the motor the only return path for the current is up the speedo cable. Mechanics often blow up speedos this way if they've had the box or motor out and forget to re-attach the earth cable properly.
You're going to need a new speedo. You also need to fix your engine earthing first.
Lucky for you I've gots heaps of them
Pete
Same problem! Your clutch cable is acting as the earth return. It's acting like a big switch when you engage the clutch and disconnecting the earth to your motor, at which point all that juice shots up your speedo cable instead.
You need to fix your earthing!
There should be a cable from the negative of the battery to the chassis and the gearbox mount. I reckon the chassis or gearbox connection is missing.
Pete
