If your oil and water temps are accurate then your car is running far too cold to be working at it's optimum efficiency.Water should be at 87 C min otherwise your car is running on cold start the whole time and using more fuel than it needs to be.Oil temp should also be up at least the same as the water to burn off any contaminants and reach operating viscosity.
Widebody Cayman S Turbo, 83 ur Quattro
2000 996 C4 cab,12 Scirocco R OEM+ STG2+
72 914 (3.2S boxster pwr), 92 G60 Corrado
76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
