Results 1 to 6 of 6
Thread: Fuchs Wheels
    Oct 2006
    Fuchs Wheels
    Hi guys
    Thinking a set of these would look pretty sweet on a MK1...
    http://cgi.ebay.com.au/ws/eBayISAPI....m=260541512702
    apart from getting adapters, is there anything else to consider offset, width etc
    Cheers in advance
    Mar 2007
    South Brisbane
    seen a similar set fitted to a mk3 golf in the latest vw performance mag didn't look to bad it also had a air cooled engine in the back
    Jul 2005
    Newcastle, NSW
    You need the confirm the offset but as they are so narrow, I reckon you could probably sneak them on with adaptors. You would probably want 4 the same width, not the 2 different widths as used on a beetle.
    Oct 2006
    Offsets are +6....4.5 or 5.5 width
    how thick adapters do u reckon i would need to run?
    Mar 2009
    go down alright..
    Jun 2007
    Eastern Suburbs Melbourne
    Quote Originally Posted by scoob02 View Post
    sorry mate, these wheels wont work, not with those offsets!
    remember a std wheel has the offset of +45 (5" rim), and already these wheels are already going to stick out a further ~40mm, then add an adapter, the thinnest are about 15mm, which leaves your final ET at about -10, which is 55mm further out than the original wheel.
    sorry mate, these ones wont work. you want to try and find replicas with a higher (ie +30 atleast!) before you can think about buying them
    Also, I believe this topic has been bought up before, have a quick search around, and i'm sure you'll find some more info.
    i like volkswagens
