id just get the smallest spacer possible if it was me.....
or the largest depending on how you want your car to look![]()
hey guys, had a call from the guy who's building my golf atm, and he said rear wheels fit mint, but fronts are gonna clip the front brake calipers.. so i can either put spacers on them... or grind a divot out of the back of each spoke for clearence... (would only be small)
firstly... to grind or to space?? which are both going to work or is it case sensitive???
give me some advise as i want to get this show on the road ASAP and wheels are supposed to be the last thing on my mind right now!!
cheers guys.
josh
2012 Ford Focus - Panther Black
Previous - 1977 VW Golf GLS - 2E (beige beast)
Previous - 1976 VW Golf Ls (flipper blue)
Wide Steelies For Sale
http://www.vwwatercooled.org.au/foru...ies-76972.html
Where should i get spacers? Anyone done this before? Brand size etc
Which part of the brake calliper is it hitting? I had this issue on my mk1 so I took 5mm off the calliper mount which seems to protrude further than the rest. I didn’t have any issues and have seen it done before on VW's and BM's
There are different brake calipers, you could use the other type and solve the problem without grinding.
I'd grind a calliper before a wheel.
grind the caliper down josh![]()
<space for rent>
So, depends on what section of a caliper you'd need to grind. And safer than a spacer in the eyes of the law.
