Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: front wheels won't fit over brakes...
    Jan 2010
    Baulkham Hills
    hey guys, had a call from the guy who's building my golf atm, and he said rear wheels fit mint, but fronts are gonna clip the front brake calipers.. so i can either put spacers on them... or grind a divot out of the back of each spoke for clearence... (would only be small)
    firstly... to grind or to space?? which are both going to work or is it case sensitive???
    give me some advise as i want to get this show on the road ASAP and wheels are supposed to be the last thing on my mind right now!!
    cheers guys.
    josh
    2012 Ford Focus - Panther Black
    Previous - 1977 VW Golf GLS - 2E (beige beast)
    Previous - 1976 VW Golf Ls (flipper blue)
    Feb 2008
    mOOROOLBARK
    id just get the smallest spacer possible if it was me.....
    or the largest depending on how you want your car to look
    Jan 2010
    Baulkham Hills
    La
    Where should i get spacers? Anyone done this before? Brand size etc
    Sep 2005
    Which part of the brake calliper is it hitting? I had this issue on my mk1 so I took 5mm off the calliper mount which seems to protrude further than the rest. I didn’t have any issues and have seen it done before on VW's and BM's
    Camden, Sydney
    There are different brake calipers, you could use the other type and solve the problem without grinding.
    Sep 2006
    Australia?
    This is the exact same thing with VRs and calipers. The later give you more room to work with and more wheels to use without having to space them out
    Jul 2005
    Newcastle, NSW
    I'd grind a calliper before a wheel.
    Sep 2009
    Chillaxing in Tas
    grind the caliper down josh
    <space for rent>
    Peregian Beach
    Quote Originally Posted by mikinoz View Post
    That's a ditto from me.
    However fixing the problem with different calipers would be the best bet.
    Aug 2009
    So, depends on what section of a caliper you'd need to grind. And safer than a spacer in the eyes of the law.
