sikaflex is the adhesive he said I need to use, because black silicone wouldnt be strong enough
Hi All,
Got my windows tinted today and they cant put the quarter ones back on because the factory latch was glued to the glass not drilled and bolted through.
The tint guys said I have to either use black silicone (has a special name) to permanently fix the window in
I went to buy the silicone at an auto spares place and he said that wont be strong enough and i need some other sort of window adhesive
either way the window wont be able to be popped in and out like the stock ones do
Anyone encountered this problem?
silastic is the other
so silastic or sicaflex which should I use?
Sikaflex...Bunnings should stock it
Pete.
I recently re-did mine, and foudn that rear view to windscreen mirror glue really easy to use, however i have read somewhere that you will have to remove the tint, in the little circle where the latch goes, mine aren't tinted, so i just glued em on, and the window in.
Good luck
Jonasz
Mine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
-MK1 Golf The re-spray/re-build
In the family: -MK5 Jetta 2.0TDI, -9N3 Polo TDI, -6R Polo TDI, -Mitsubishi S^$&box van
A pattern seems to be forming...
sorry to hijack th e thread but does anyone know if its possible to get new opening quater light window rubbers?
1988 corrado G60 LHD dark green, full miltek , borbet e's .k w coilovers
2006 T5 tdi semi auto
1977 mk1 gls 2 door,1.8 on twin 45 dellorto's
2002 bora 4 motion,kw coilovers,x force full stainless,r32 rims
Not opening but fixed window rubbers? Maybe an option..
eBay Australia: Buy new & used fashion, electronics & home d
I am trying to keep it stock,does anyone know if they are making repro ones yet?
You'll have to double check the part numbers but looks like VW classic parts do them still. Not cheap at 95.58 euros less 19% tax plus postage, which is quite cheap.
171837530B right seal
171837529B left seal
gav
