Results 1 to 10 of 13
Thread: Front quarter windows
    Nov 2008
    Hi All,
    Got my windows tinted today and they cant put the quarter ones back on because the factory latch was glued to the glass not drilled and bolted through.
    The tint guys said I have to either use black silicone (has a special name) to permanently fix the window in
    I went to buy the silicone at an auto spares place and he said that wont be strong enough and i need some other sort of window adhesive
    either way the window wont be able to be popped in and out like the stock ones do
    Anyone encountered this problem?
    Nov 2008
    sikaflex is the adhesive he said I need to use, because black silicone wouldnt be strong enough
    Nov 2008
    silastic is the other
    so silastic or sicaflex which should I use?
    Jun 2012
    Hackett, ACT
    Sikaflex...Bunnings should stock it
    Pete.
    Jun 2012
    Adelaide, South Australia
    I recently re-did mine, and foudn that rear view to windscreen mirror glue really easy to use, however i have read somewhere that you will have to remove the tint, in the little circle where the latch goes, mine aren't tinted, so i just glued em on, and the window in.
    Good luck
    Jonasz
    Mine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
    -MK1 Golf The re-spray/re-build
    In the family: -MK5 Jetta 2.0TDI, -9N3 Polo TDI, -6R Polo TDI, -Mitsubishi S^$&box van
    A pattern seems to be forming...
    Jun 2012
    Quote Originally Posted by joshcrd View Post
    Hi All,
    forgot to add, you can get it from almost any car shop, like repco etc.
    Jul 2009
    WA
    sorry to hijack th e thread but does anyone know if its possible to get new opening quater light window rubbers?
    1988 corrado G60 LHD dark green, full miltek , borbet e's .k w coilovers
    2006 T5 tdi semi auto
    1977 mk1 gls 2 door,1.8 on twin 45 dellorto's
    2002 bora 4 motion,kw coilovers,x force full stainless,r32 rims
    Oct 2006
    Albany Creek Brisbane
    Not opening but fixed window rubbers? Maybe an option..
    eBay Australia: Buy new & used fashion, electronics & home d
    Jul 2009
    WA
    I am trying to keep it stock,does anyone know if they are making repro ones yet?
    Nov 2009
    You'll have to double check the part numbers but looks like VW classic parts do them still. Not cheap at 95.58 euros less 19% tax plus postage, which is quite cheap.
    171837530B right seal
    171837529B left seal
    gav
