Results 1 to 3 of 3
Thread: Fitting an ABF motor in a 2009 mk1
    Hi guys, a mate of mine has just bought a mk3 gti ABF and he wants to do an engine swap into the mk1. the mk1 is using mpi ecu with a ffz gbox.
    Will the abf motor be a straight fit into the mk1 and will the ffz mate straight onto the motor?
    Help would be much appreciated.
    Ex: MK1 citi 1.4i 140db 64kw
    Ex: '96 VR6
    Current: Mk1 Citi .:R 1.8i 90kw
    Current: Mk1 78 2door narrow bumper 1.8 16v Kr Project
    Boronia VIC
    FF box will work so long as you have the small shaft clutch driven disc to go with it.
    ABF will fit in bay mechanically but is a little taller so you might have clearance issues with the bonnet.
    You'll need special extractors to suit 16v in MK1 chassis.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Boronia VIC
    Oh just realised you said 2009 MK1, also just realised where you are.
    What motor does the car have now?
    If it's a 1600/1800 derivative what I said above should be OK. If it's got one of the small block motors you might have to weld in an engine mount.
    FFZ looks to be a very late member of the 020 series so should work OK but may not be the strongest. Whatever clutch disc you use has to suit the gearbox input shaft.
    7? MK1 Caddy
    12 Amarok
