engine number is stamped on the block, right where the head and the block join, infront of cyl No 3. might be blocked a bit by the radiator hoses.
golf got rwc today and the mechanic said he couldn't find the engine number and got it off rego papers in the glovebox, i checked the the owners manual and it said its on the front of the block below the join of the head and block but i could not see it. now with the diesel the throttle body is in the way a bit but there seems to be two empty screw holes?? is the engine number stamped on a plate and affixed to the the engine, or is it stamped on the engine and im just blind?
if its a plate can i get a replacement?
Above the two empty threads behind the fuel pump.
Can barely make some numbers out here.
Mine's got a heap of crud on it, degreaser is your friend.
thanks jarred and jace the photos help.. mines about a billion times grimier than that.. will degrease it and have a look tomorrow.. just incase vicroads need to see it!!
They will, if you get one of the old guys who knows his ****. From my experience, the babes don't really care, but the old bastards will deny you if they can't find it.
yea, they'll have to see it, cause it's a new rego.
like was said, degreser and then some WD40 and a light sand if needed. (worked on mine)
