Page 7 of 16 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 157
Thread: Erik & Rupert: The Tale Of Two MK1s
  1. #61
    Jan 2010
    Melb Westsideeeee
    Broadway mirrors are god damn awesome !
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
  2. #62
    Dec 2009
    Melb, VIC
    Great work so far mate, your getting close for sure!
    Whats the plan for the green one long term? are you going to keep it?
    I really hope so! We'll see where we're at after tomorrow's effort. Would love to have it at the VW Nationals later next month.
    The coilovers have been identified by others in a similar way. They seem to be those same rebranded ones sold by JOM etc.
    Long term the green one will be sold. In fact not that long term, I'll be looking to sell it as soon as it's back together. I have had a bit of interest in it already including an offer to trade for something else that I really want, so that might work out.
    Quote Originally Posted by GeorgeMK1 View Post
    Yessir! I love 'em. This will be the third car I've had this one in. Haha.
    I did this last night. Just a test fit. My friend has them up for sale at the moment.
    It was only semi-successful. While I was able to get them on the car, the front wheels do not clear the brakes. If you line up the wheel so that the caliper sits between two of the bolts holding the wheel together, it mounts to the hub, but it needs an 8-10mm spacer to make it work, and there's no room under the guard to do that unless I run a stretched tyre, which I don't want to do this time around.
    It's disappointing as the fitment is pretty much perfect for the look that I want. At least I know what I'm looking for now, I just need something with slightly better disc clearance.
    The search will have to continue. I'm glad I at least tried them out; if they sold before I had a chance I'd have been kicking myself!
  3. #63
    Dec 2009
    Melb, VIC
    I've been doing bits and pieces of work on the cars over the last week, but progress has been a lot slower than I'd like.
    In order to change the dash looms over I needed to swap the column switches, but because one column had a spline adapter and the other one didn't, I had to take them both out and swap them too.
    After taking the column out I realised that the bottom bearing in the yellow car had fallen apart, but the assembly in the green car was okay.
    NEK MINUT. I took them out and it was really annoying to get back in. Adjusting the brake linkages and the pedal height to be just right took way too long. I still need to do the one in the green car.
    I took both dash looms out after that but they're still on the ground just like in the photo. At the moment I'm tidying up the wiring in the yellow car's engine bay, then I'll hook it all up at the same time.
    The next hurdle is the fuel setup which will either mean swapping fuel tanks between cars or coming up with a new system in the yellow car. Not too sure yet.
  4. #64
    Sep 2009
    Chillaxing in Tas
    You can fit the wheels mate, just buy some GTi calipers, they are alot slimmer, and actually sit behind the hub surface to allow better rims to fit.
    not only do you get better brakes, you get more wheel options,
    Car is looking great, well both actually
    <space for rent>
  5. #65
    Dec 2009
    Melb, VIC
    The yellow car actually has GTI brakes! Or so I've been told. Here's the photo.
    Clearance is way better than the normal callipers on the green car, but they don't sit behind the hub completely. It's not a big deal anyway since I should really hold onto the money for now until the car is working. Not sure what other expenses might crop up.
    Thanks for the kind words.
  6. #66
    Sep 2009
    Chillaxing in Tas
    Yes those are GTi Brakes
    I couldnt remember if they sat flush or just over the hub.
    <space for rent>
  7. #67
    Dec 2009
    Melb, VIC
    Update time. Things are back in gear and I'm feeling much more positive about the progress. These photos are all courtesy of my mate Danny who was helping out.
    We started out last night with the car looking like this. Pretty barren in there. It's been looking this way for a while.
    First job was tidying up the loom from the green car to go into the yellow car. It was a mess. We spent a while stripping out the unnecessary stuff and soldering up the dodgy connections. It's in much better shape now.
    After that we got the heater/fan box thing out of the green car to switch over as well. I had this brand new heater core ready to go in while the unit was out.
    Once that was back together we started putting them both in their new home. We need to drill holes to mount the heater unit properly, but that's no big deal.
    While all this was going on the two of us were keeping one eye on these ATS Type 5 wheels. They were up for auction on Yahoo Japan. One thing lead to another and I bought them. So that's something else to look forward to.
    Next step is sorting all the engine bay wiring and coolant plumbing, swapping the fuel setups and then starting the damn thing. So keen for that to happen and it's finally in sight.
  8. #68
    Dec 2009
    Melb, VIC
    Can someone tell me what this thing is? It lives up in the top of the engine bay but both hoses were cut and it was just sitting there.
  9. #69
    Jan 2010
    Melb Westsideeeee
    Every mk1 ive owned has had them cut off - So i just remove it. I believe its something got to do with emmisions control ?
  10. #70
    Dec 2008
    Perth
    that's a carbon cannister for the exhaust gas recirculation gear, there is another under your driver side front guard throw them both in the bin rust loves to take over behind them! project is looking great
