Results 1 to 6 of 6
Thread: Engine mounts and brake discs
    Apr 2006
    Melbourne, Victoria
    Hi all,
    Im in the process of preparing threee Mk1 golf diesels for roadworthy and im gonna need some parts. Multiply the following by three:
    Front discs
    Engine mounts
    Are there any other makes that i could find these parts on at a wrecker that i could bolt on? Vented perhaps? If not then who would be a good supplier in Victoria?
    One engine has a blown head gasket and another needs rings but thats a question for the diesel forum
    Thanks
    Matt
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
    Mar 2006
    WA
    I think i have some standard front discs you can have for the cost of postage assuming they are still within thickness, any idea what the minimum thickness is?
    -Jamie
    76' Mk1 Rally Car, 1800 8v haltech ecu
    94' Fairmont Ghia, v8, big cam, leather, perfect for towing golfs
    89' EA ex taxi, lpg, cheap and easy
    Not to do you out of a sale Jamie.
    Surely you can stand the cost of some new discs. In the UK the likes of gsfcarparts.com do discs for peanuts. The vented GTI ones are less than a tenner each.
    You might find that the early diesels can only use solid discs due to the calipers fitted.
    syncro Guest
    Be careful, diesel and petrol engine brakes are different.
    An upgrade is to go to LS/GLS brakes which are easier to get.
    Even the pads are different.
    Apr 2006
    Melbourne, Victoria
    Thanks
    so if i want to put vented discs on the front then i should fit petrol calipers.
    I took a vernier to pick a part today and discovered that honda 4 x 100 pcd front discs are the same offset, diameter as the golf discs only vented. I wanted to check here before i handed over the cash.
    If new discs are cheap, where can i get them (vented too) in Aust, other than off a honda at pickapart?
    Thanks
    Matt
    TassieGTi Guest
    If you want vented discs you need a pair of early GTI calipers.
    Try Eli at Imparts.(girl)
Similar Threads
  1. VW Engine Number Chart
    By Golf Loon in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 14-09-2009, 03:20 AM
