Results 1 to 6 of 6
Thread: Park light issue
    Sep 2006
    Australia?
    Question Park light issue
    Hey Guys
    Just wondering if you could help me, in the mk1 I have a weird issue with the park lights, more the left hand side park lights.
    Its the front and rear actually. When you turn on the park lights the front parker in the headlight doesn't turn on
    And either does the parker in the rear left tail light
    I checked the globes and its not that so I'm thinking is it a fuse or something? As the right hand side is fine so not sure what it is
    Help appreciated!
    Thanks Steve
    Oakleigh VIC
    Is your indicator centred? Sounds like an issue with the euro parker setup.Check wiring behind the emergency flasher switch and indicator stalk as well as fuses.
    Pete
    Apr 2006
    Hobart,Tas
    Easy fix I reckon.
    Best buy a test light or voltmeter!!
    fuse...
    Sep 2006
    Australia?
    Thanks Guys
    Andrew Fuse?
    Apr 2006
    Hobart,Tas
    yes, more than positive, easy find with a testlight and an easy fix if it is!
    Sep 2006
    Australia?
    Yep thanks sorry didn't quite know what you meant my just that will check soon thanks guys
