You have electric windows?
My MK2 doesn't.
i need 1 window switch for a mk1 cab. and wondering if are they a mk2 item.
anyone know where's best to source one from.
also, the alternator is only just charging at 13v, would this be consistent with worn brushes?
eric
My MK2 doesn't.
They look like BMW E30 switches...
there are some sort of blank plate where the winders go.
the face plate for the switches has the switch plate plastic welded in, and the centre gauge cutout in the console has been butchered.
and all the wiring is home/shop done. guess it must be retro fitted from something?
voltage was taken across the battery, so will check from the alternator tomorrow. battery holds 12.65v, and running between 12.85 / 13v, varying the revs makes no difference
cool, i'll take that temperature!
Thats an Electric Life window kit. I guess the switches died and they have been replaced.
