Someone has been in here before
( replaced rivets )
Wash out everything, check the syncro side clearances and see if they are kaput. If not then replace all seals, clean the magnet. and re assemble.
Looks like it had a case gasket ?? make sure you put a new one in on assembly . I ditch the gaskets and use the VW sealant on the case halves, but you need to check the bearing preloads and adjust accordingly if you go this way.
Good luck.
Lots of MK 1 Scirocco's...
Cheers,
Grant...
