Thanks team, I will go and worry about something else for a while
c
It's been a while...
This info is spot on!
I've also had to carry out this mod as well using mk1 shaft's. I used the standard outer CV's & have only hammered one of them.
Also after nearly 300+k, my inner 100mm's started to grind on big bump's (that & the car was already low), so I removed both the inner's & swapped the gut's of them around & never had a problem since. They say you shouldn't do this, but I thought I'd give it a go anyway.
how the hell can you go through that many?
I've only ever done one CV & I've rally bashed, dragged, burnout's (incl. reverse), raced, jumped etc. over a 400+k period.
