Results 1 to 10 of 17
Thread: Does Not Want To Start
    Nov 2006
    Newcastle NSW
    The problem has only happened 4 times so far and I cannot see a pattern such as been driving for a long time or just a quick trip as it has happened on both of these occasions. You get in, try to turn the key and get NOTHING. Its an auto so I tried putting it into Neutral and trying to turn key - NOTHING. Put it back into Park and turn key - NOTHING. Voltage guage is showing slightly under the red mark and lights are on the dash but its not even trying to crank over. If I wait a little while, it will start just like normal!
    It also has a problem when sometimes you put the blinker on to go around the corner, the wipers come on - usually just one sweep across or even just a little nudge, but I can live with that. I can't live with the not starting when you want it to.
    Sorry, should have said its a 77.
    "One is too many, three's not enough" Harry's Reasons - V Spy V Spy
    Jul 2005
    Newcastle, NSW
    When the ignition starts to degenerate this is common. I have had the horn when starting, the wipers when indicating and many other combinations.
    I replaced it with another and all have gone. May be your problem too?
    Nov 2006
    Newcastle NSW
    Thank you. Is there any check that I can do or is it a mechanic only thing?
    Jul 2005
    Newcastle, NSW
    I pulled the steering column off myself and replaced the whole unit with a Haynes manual. I am not sure how much they cost, but if they were cheap enough I would suggest replacing it anyway. You don't need to replace your key by the way.
    Camden, Sydney
    Next time it does it, try lifting the key as you turn it, if it then starts its the ignition switch.
    Bit fiddly to fit yourself, but can be done. The switches are cheap.
    Feb 2006
    Perth Western Australia
    I'm with loon on this, most old mk1's have problems with the ignition switch, if lifting the key doesn't help remove the plastice covers around the steering column stalk and push the ignition switch wiring plug up and see if it starts. If it isn't this and being and auot it could be heat soak in the starter motor as it sits just under the exhaust manifold on autos. If it does it on very short drives then I doubt it is the starter motor
    77 Golf tarmac rally
    89 porsche 911
    80 Rabbit 4dr
    11 mk1 and 2\'s in various states of undress
    KEEPING THE BIG CUBES IN THE REAR VISION MIRROR
    Nov 2006
    Canberra, Australia
    Sounds like our house when it was in the middle of getting its wiring brought into the 21st century. I came home one night after work, turned the lights on and they all blew. I turned the cooktop on to see if there was any power and the lights in the hallway came on, haha.
    MY10 S3 3dr
    Nov 2006
    Newcastle NSW
    Thanks guys. I will report back on how it goes, the next time it does it.
    It happened yesterday when my daughter was driving and it freaked her out a bit - being 16 and all - with me I just shrugged and said it will start again, don't panic.
    Jul 2005
    Newcastle, NSW
    It can have other side effects like faster window wiping and brighter lights!
    Apr 2006
    Hobart,Tas
    A very common problem on the autos is the solenoid on the starter. They produce an intermittent starting problem and the only real cure is to replaced it or if you have a really dialled in auto electrician, they can dismantle the sealed solenoid and replaced the top cap section of it.
    Look forward to hearing the cause of your problem,
    Good luck, Andrew
