Results 1 to 2 of 2
Thread: Do the mk2 16v run a 8 volt coil system?
    Aug 2011
    Hornsby, NSW
    Or am I just talking out of my ass? I thought I heard someone say this and I tested the coil and it reads battery voltage as in 14v... Should I put a resistor in or is that normal?
    Gosford Central Coast NSW
    Hey local,
    Mk2 should be electronic ignition system with a 12V coil. What 16V is it?
    only the points ignition models ran the lower voltage coils.
    PS - if you need any advice for your car, I work in Mt Kuring-gai industrial estate.... very close to you!
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
