Results 1 to 3 of 3
Thread: What fuse goes here?
    Jun 2008
    Hobart, TAS
    Hey guys,
    just putting a headunit in my car atm, but it's not working.
    power supplies are good and work fine but still can't get it to fire up.
    I'm running the battery wire off the cigarette lighter power supply, and the acc off the ignition wire (black with yellow trace).
    The only thing I have noticed is that the very last ceramic fuse in the fusebox has been removed but i have no way of knowing what rating fuse goes in there. That's where i pass over to you guys for an answer as i my service manual hasn't arrived yet.
    Let me know what you guys have there and what you have done with ur installs.
    oh btw my car is a 76 mod mk1
    cheers,
    Michael
    1979 Mk1 Golf GTi
    1994 Mk3 Golf VR6
    Perth. WA
    fuse S15
    for 75 its the fuse for fog lamps, for 76 onwards its the fuse for radiator fan if not relayed, As to the rating of the fuse the 1980 model had a 25 Amp fuse fitted.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Jun 2008
    Hobart, TAS
    oh ok, thanks for that.
    It now works
    except my start button won't (yes i have a start button)
    It's not going the greatest atm
    1979 Mk1 Golf GTi
    1994 Mk3 Golf VR6
