Run a carter rotary fuel pump, much better than the facit style pumps that are noisy.. Fuel pressure regulator for 2.5 psi suits weber, dellorto carbs. The factory engine block mounted fuel pump cant flow enough fuel for anything above a downdraft 32/36 carby.
I would recommend electronic ignition as well for reliabillity and a little more power. Points wear quickly.
